relevant wall thickness
Hi
I work on casting that has different wall thickness in different areas of casting. How I can determine the relevant wall thickness of a casting?
RE: relevant wall thickness
Do you mean nominal, or thinnest that a section can be to maintain structural integrity? In any case, the fabrication drawing should have this information specified.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
"The size of the sample shall be in correspondence with the relevant wall thickness of the casting",
In the definition of relevant wall thickness was written:
section of the casting, to which the determined mechanical properties apply.
so I need to know relevant wall thickness to choose a correct test sample.
Are you sure that it is the thick section of castings?
The sample is cast separately as a Y block or Kill block. The size of Y block is related to relevant thickness of casting. In standard there is table for choosing test block dimension regarding to casting relevant thickness.
" Test coupons and casting properties."
http://www.sfsa.org/sfsa/pubs/testcoupons/tc.pdf
