Synchronisation of gates motion
Any suggestion would be highly appreciative concerning the synchronisation of gates motion. (see attached picture). Which mechanism should I use for the synchronization. Chain mechanism or a threaded rod or else.
Thanks and regards,
Thanks and regards,
RE: Synchronisation of gates motion
I can envision gross differences in position based on frictional variations at the pivots. A chain seems more positive in assuring rotation at each wing. One question is what real estate is available to accomplish the motions?
You realize if you use a coupler link as in the pic that it becomes a 4-bar analysis.
Depending on the position of the coupler link and the length of the coupler the motion of the input and output gate may not be perfectly synchronized (or even very different). You will have to analyze it accordingly.
Perfect synchronization is easier with a simple sprocket and chain or timing belt and pulleys. You can use zero backlash sprockets to eliminate variational pose error when changing direction.
I am not saying it is not possible with a link. Just pointing out the problem.
Fe
@dvd: By writing synchronisation, I mean angles should be the same for both gates in both closed and open conditions. The answer to ur last question is that a pneumatic cylinder originates the motion of whole structure.
You will have problems with this requirement as I see your intent.
Fe
