Amada FO laser head help
Hi all,
I'm hoping some can assist with some questions i have Re the Amadao FO laser heads.
I just recently purchaed an Amada FO, has the WACS option but didn't come with the WACS head.
Now i beleive there is also an ECO head as well, i didn't get this one with the machine either.
Can you guys tell me what the ECO head actually does? i believe it allows for high speed peircing in thicker plate? is this true?
Do you guys use WACS if you have it on your Amada machines?
Should i spend the time & money tracking down both the WACS & ECO heads for my machine?
Thanks in advance for your input.
Cheers
Kane
Cheers
Kane
RE: Amada FO laser head help
The ECO Head has air coming out of the cone to help cool the nozzle as well as for piercing and blowing spatter away, the nozzles are also different, they look like a mushroom. I have seen many customers ditch the HS-98 Head for this one to cut all their materials whether stainless, aluminum or steel. My experience for the HS-98 Head was mostly for cutting thin materials at speed since the cone is taller and more tapered and it doesn't collide as much with parts or cutouts that tip up.
Hope this helps.
Thanks for the info, i can easilly purchase new WACS or ECO cones, seems i can't get the rest of the head easily or reasonably priced.
i will keep an eye out on Ebay.
Cheers
