orient an shell element
I work currently on a surf's fin geometry on composite.
I mesh its areas with the element type shell91.
I want to study the orientation of the different layers, so i have oriented my fibers with the way : Preprocessor>RealConstant>...Material/Theta/ thickness
And i have realised after check the element system that all the orientation is different for each mesh. The angle depends of the I,J,K,L corners of my mesh and not of my x,y,z global coordonate system!!!
All my results are false!
Somebody knows how i can simulate my composite?
Any help can be usefull!
Thank you
Benjamin
Thank you
Benjamin
RE: orient an shell element
And i haven't found a good tutoral or explication to explain this command. :s
I go in workplane>coordinate... And i use a cylindrique coordinate. the result is really better!
