regulation problem
regulation problem
hallo, dear all!
i have a question. i am designing dosing a fluid from a tank via pump into two reservoars opened atmosphere where the constant dosing is required i planned a backpressure regulation and it works, everything is in horizontal position...now i want to do the same system with vertical position? does somebody knows already what can get wrong? what do you think happens with flow floctuations in flow of reservoar 1 and 2. please see attached image
can you write flow control equations etc or did somebody did something like this already
thanks
thanks
RE: regulation problem
