Inconsistancy in finding subassemblies at different assembly levels
I don't understand why I am getting the result I am.
I have subassembly A. I can open this part file and it loads OK.
I now close all pats and load the next higher assembly which includes subassembly A as a component. In this case subassembly A can not find some of its components.
If it finds all its components in the first case how is it that it can not find those same components when loaded in the second case?
There is only a single subassembly A in a single directory. In both cases "INFORMATION" on subassembly A shows its location to be the same and its version to be the same.
The assemblies are being loaded "As Saved"
I am going to pull up the subassembly A first, then the upper level assembly and then re-save the upper level assembly. Hopefully that will solve my problem but I would like to understand what is going on.
I am using 7.5.2.5 NATIVE on Dell with windows XP OS
RE: Inconsistancy in finding subassemblies at different assembly levels
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
