IEC motors, what type tests are required?
what is the iEC standard for type tests?
i now editing general specification for motors and want to put a list of required type tests ,
RE: IEC motors, what type tests are required?
IEC 60034 covers most aspects of rotating machines.
what part of iec 60034 deal with type tests?
Suggest you obtain a copy of IEC 60034 Document & refer to Testing of Motors.
If a prospective manufacturer has previously produced & tested a motor of the exact type that you require, they should be able to furnish you with a type test certificate at the inquiry stage.
One important item in a type test is the Heat Run performance.
I appriciated getting the list of motor type tests, even without any  detailes
thanks
