"margin on failure"
"margin on failure"
"margin on failure"
Can anyone help me with the definition of "Margin on failure"?  and more specificly what does a MOF of 1.3 mean?
thx
j....
RE: "margin on failure"
Is this a Safety Factor or sometimes referred to as a Factor of Safety
Margin of Failure is a slightly different way to express the Safety Factor. An example is the easiest way to clarify the difference:
Say that a simple beam has a 10 kip load applied, but the beam fails when the load is 23 kips (applied in exactly the same way).
The Safety Factor is:  23 kips / 10 kips = 2.3
The Margin of Failure is:  (23 kips - 10 kips) / 10 kips = 1.3
www.SlideRuleEra.net idea
www.VacuumTubeEra.net r2d2
Thxs SlideRuleEra, I haven't run across this term before and was unsure of what the author of the report I was reading was trying to convey.
Thanks again,
j....
