materials for butterfly valve's
What are the most common materials used for butterfly valve's(housing/disc/stem/rubber)?
I'm applying for a job as a valve engineer and would like to know where to best focus my preperations on (regarding materials used).
Thank you kindly!
RE: materials for butterfly valve's
321GO,
There are obviously many different materials used, based on the intended application, however I would say the most common are:
Body: Ductile Iron, Cast Iron, Cast Steel (WCB)
Stem: 416SS, 316SS
Disc: Ductile Iron w/ Nickel plating, Aluminum Bronze, 316SS, Nylon coated Ductile Iron, Teflon Coated WCB
Seat: Buna, EPDM, Viton, Teflon
there are many other configurations of course, exotic alloys and such, but the above are staples in the commodity market.
Again, thank you!
321GO - got your job yet?
if not, you started correct in my opinion, you will find a lot of information searching this forum!
Good luck!
Have send out my application today! (hope for the best)
Thank you!
