Glulam in RISA 3D
Glulam in RISA 3D
Glulam in RISA 3D
I can't seem to find the selections for PSL or LVLs in RISA wood pull down menu (materials.) Is the selection supposed to be under "Grade" & then "dense structural D86/D72/D65" ?
RE: Glulam in RISA 3D
You can add your own sections and grades to RISA
LVL's and PSL's aren't glu-lams.  Instead, they are "engineered wood products".
The newer versions of the program come wired in with some of these common materials as defaults.  But, older versions do not.  That being said, you can still add them in using the "custom wood species" spreadsheet.
