BTH-1 2005 combined normal and shear stresses - how to apply
i am designing a drill casing pulling lug.  the lug will never see the loads it is designed for but i want to have a complete design i can stamp and file away.
Question:  how do you determine the shear stress that is used in the formula (3-37) that determines fcr?  the most conservative way is to use a single plane thru the lug, not sure if that is right.
any thoughts are appreciated,
i have attached a sketch and some calcs so you can follow along my train of thought.
thanks in advance
RE: BTH-1 2005 combined normal and shear stresses - how to apply
bump?
i hope i have not enclosed too much information, what i am looking for is the correct interpretation of the formula:
fcr = (fx^2 -fxfy + fy^2 + 3fv^2)^.5  is less than   Fcr= Fy/Nd  (3-37) from BTH-1-2005
this is the interaction formula for normal and shear stresses.
thanks
It is just the comparison stress (I think von Mises) for the plane stress case when (fz=0); this you compare with the limit strength stress by your code.
In the case of the old spanish MV-103 (steel code) where I have checked the equation all was set at the factored and limit strength level. It might be otherwise in your code, that I don't have, but would be rare, von Mises is usually seen against limit strength.
ishvaaag, thanks for your response.  i will look further into this.  the code is "Design of Below-the-Hook Lifting Devices"   ASME BTH-1-2005 if anybody is wondering
