Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say THANKS for the forum. The knowledge I gain from your site is invaluable..."
Geography
freerangequark (Mechanical)
28 Jul 11 10:29
I'm using Wildfire 4.0 for personal use and I do not have Intralink, PDM link or any type of file management or version control software.
Is there low cost software that will help me manage my PRT and ASM files?  Right now every time I save my work, Wildfire creates a new versioned part and my folders are getting pretty filled up with old versions.
Is there a config setting that will limit the number of versions for a given part?
Also, if you can't recommend software to help me out, are there any strategies you can recommend to help me manage my files.  Right now it seems my best approach is to keep everything in one folder without the use of subfolders for different parts such as hardware and so forth.
Thanks!
looslib (Mechanical)
28 Jul 11 11:20
I would separate 'common' items into one or more sub-folders and use a search.pro file to locate them.
Serach the internet for 'purge proe files' and you will find a lot of hits for programs to do this.
Ben Loosli
aafuni (Mechanical)
30 Jul 11 9:00
If you want you are welcome to have the batch file I use.  I put the batch file in each model folder, and when you run it it creates a sub folder called "old" and moves all but the current file into the "old" folder.  It also goes through and deletes the log files and other scrap files.
Let me know if you want it.
31 Jul 11 22:50
aafuni,
I would really appreciate you sending me the file :)
Thanks!
aafuni (Mechanical)
1 Aug 11 8:57
1 Aug 11 11:29
Thanks again! :)
Close Box
Join Eng-Tips® Today!
Join Us             Close
