MOTOR FRAME SIZE
MOTOR FRAME SIZE
MOTOR FRAME SIZE
CAN ANYONE SUPPLY OR DIRECT ME TO THE MECHANICAL DIMENSIONS
OF A MOTOR WITH A 42CYZ FRAME ?
THANX........ED
RE: MOTOR FRAME SIZE
Suggestions:
1. Check NEMA Std MG-1
2. "Baldor Motors and Drives" manufacturer states on the back of its catalog (Januray 2000): "Contact your local Baldor Office for "C" dimensions." It means dimensions associated with the NEMA Frame 42.
The EASA Technical manual shows the following meanings for the suffixes on your 42 frame motor.
C = C Face mounting on drive end of motor
Y = Special mounting dimensions (Call Manufacturer)
Z = Special extension to shaft length or double shaft
Not much help.  I think you need to contact the manufacturer.
