HTRI to check required static head for thermosyphon
Dear members:
My boss would like me to use HTRI to calculated thermosyphon required static head
Could you please help me to set up this input? I already paste my example and please correct me if I am wrong.
Q1. Drawing 1. How to decide the inlet pressure location?
Q2. Drawing3,4. What is the header means? How to measure the header's distance?
Q3. Draiwng3. Is possible to adjust the straight pipe height to get required static head? .
Ex. To meet the specific inlet flow rate, use trial and error method. say inlet equivalent length =5000~1000mm and height change =-5000~-1000 mm to find out this specific flow rate.
Thank you.
Thank you.
