NX7.5 drawing views with Hidden Line Removal turned off
I received a bunch of NX7.5 drawings and the drawing views have Hidden Line Removal turned off. I figured out a way to turn hidden line removal on per view but it takes a while. I'd like to turn them all on at once. Is this possible. While i'm at it i'd like to cycle thru the drawings and have it done to all of them with a script or something
RE: NX7.5 drawing views with Hidden Line Removal turned off
I guess the easiest way to do that would be to go into your part navigator, expand the drawing sheet, then select all the views (click on the view that is listed on the top, then hold your shift key down, and pick the view that is listed on the bottom), then rmc (right mouse click) > style > hidden lines > change "invisible" to "dashed"
Good suggestion!
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
