PATRAN --- Import CATIA
I found error message during import file CATProduct from CATIA, "The CATIA V5 CATProduct import fail. Verify that all the subordinate CATPat/CATProduct files are in the same directory as the parent CATProduct file and try agian". How do I solve it?
P.S. I use CATIA P3 V5R19 and MSC PATRAN/NASTRAN 2007.
RE: PATRAN --- Import CATIA
Check if you have the right import licenses to ijport R19 products.
THis error message happened to me once and was never able to get rid of it. I had to ask a collegue to import the parts for me.  This got solved for no reason when I updated to an earlier version of Patran.
MSC was helpless to help on that matter.
Good luck.
