Pro-E Issue
Pro-E Issue
Pro-E Issue
I'm having problems getting rid of some issues, attach is a screen shot with notes on what the problems are. If ant one could help it would be appreciated.
RE: Pro-E Issue
Welcome to Eng-Tips.  You probably should post this in forum554: PTC: Pro/ENGINEER as you will find people there who use the program.
Once you've posted there, red flag this post (look for the words "Inappropriate post? If so, Red Flag it! at the bottom of each thread) and tell the moderator that you've posted in a more appropriate forum.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: Pro-E Issue
Can you check for interference in assembly.  Drawing generated often get twitchy when having to resolve interference
RE: Pro-E Issue
Tipp-ex?
