How To make a real torque reading
Hello All
I am looking a good information in order to know how to take good and real torque readings in loaded electric motors (some instrument? anything available in the market?) not calculating the torque based in other electric parameters.
Thanks for the inputs
Petronila
Petronila
RE: How To make a real torque reading
What size motors and what type of drives?
Direct drive?, belt drive?, built in motors?, do you have room to instal some type of torque transducer on the motor shaft?, is it possible to measure the torque reaction of the stator?
Bill
"Why not the best?"
Jimmy Carter
I can't find it right now, but there's one meant for permanent installation.
Waross: Direct drive size up to 1000 HP
Carlos
http://www.binsfeld.com/index.php/products/TT10K/
It is very adaptable to various size motors whether in plant, lab or field installations. It also provides dynamic torque for statup transients and torsional vibrations. I measure shaft speed with an optical tachometer so that I can calculate true HP.
Walt
http://
Good links
Carlos
