Pb when importing a dxf file from architecture software
I am trying to use NX to draw my new home. The geometer send me the plane field with dxf (see attachment file). I was able to read it but some entities are unselectable because they are at the following coordinates:
Information Units mm
XC = 797005.766000000
YC = 259552.868000000
Z = 0.000000000
Is there any settings in customer defaults ?
Z = 0.000000000
Didier Psaltopoulos
http://www.psi-cad.com
RE: Pb when importing a dxf file from architecture software
The remedy is to increase the max fix box size, which can be done either by setting UGII_MAX_FIT_BOX_SIZE=320000 (any larger value up to 1000000 would also work), or by doing the equivalent via Customer Defaults, in Gateway -> Visualization -> View/Screen -> Maximum Size for an Object's Bounding Box. If desired, you can change this value in Customer Defaults to the largest possible value, which is 1000000 mm (= 1000 m = 1 km).
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, Beta NX8.0.0.23
Thanks a lot, It's OK
Didier
Didier Psaltopoulos
