How do I save/display the return from the splitString()?
How do I get rid of the first word from a string?  For instance, I'd like to display "is a test" from a given string "This is a test".  Thanks!
RE: How do I save/display the return from the splitString()?
Does this question relate to a journal? If so, the Split function returns an array of 'words' based on the delimiter you specified.
http://msdn.microsoft.com/en-us/library/6x627e5f(v=vs.80).aspx
If this isn't part of a journal, ignore the above link! smile
no sad
I am trying to put this biz logic in a "Note"
Where is the source string coming from (drafting note, attribute, external spreadsheet, database, etc)? Where do you want to put the result (appears to be a drafting note based on your post)?
The string is from db_part_no.  Yes, the result will be put in a drafting note.
I have not found a straightforward way to do this, but here is a small journal that will take the DB_PART_NAME attribute, process it and assign it to a new attribute. You can then reference this new attribute in your note. You could set up a custom button or menu item to be run at will or set it up to run at a 'user exit' point (file open, file save, etc) so it runs automatically. The journal operates on the work part. Save the following as a text file and change the extension from .txt to .vb.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Sub Main
Dim strPartName as string
  Try
    strPartName = workPart.GetStringAttribute("DB_PART_NAME")
    strPartName = Trim(strPartName)
  Catch ex As Exception
    strPartName = ""
  End Try
  'msgbox(strPartName)
  if InStr(strPartName, " ") > 0 then
    strPartName = Mid(strPartName, InStr(strPartName, " ") + 1)
  end if
  'msgbox("$" & strPartName & "$")
  'the next line will create a new attribute with the processed text, change the name as necessary
  workPart.SetAttribute("CUSTOM_PART_NAME", strPartName)
End Sub
End Module
I can already think of some improvements for this, but I'll throw it out as is to see if this approach will even work for your situation.
Thanks a lot!  How do I set it to run on "file open"!  Sorry, I am new to UG.
It's been a while since I have set up menu files, user exits, and such. Your best bet would be to search the help files with a term such as "run journal from menu item", see what you can get from there and post questions as needed.
