Bolt Circle Change in an Unparametized Solid
I have an unparametized solid where I need to change a bolt circle that contains 20 holes.
I will move them one at a time if I need to but . . .
Is there an easy way to move all the holes at the same time using a command in syncronous modeling?
RE: Bolt Circle Change in an Unparametized Solid
You could use Cross Section Edit in Synchronous modeling history free mode.
If you wish to change the orientation (angle of the holes but not the radius/diameter of the bolt circle, that shouldn't be a problem using Move Face.  However if you're talking about changing the radius/diameter it might be easier to delete 19 holes, move the remaining one out radialy and then do a copy face to get the 19 back in their new radial location.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
I was talking about changing the diameter of the bolt circle - so removing them and re-adding is fine. btw, i am on NX6
This is where a feature recognizer would come in handy, both Solid Edge (ST 2) and Solidworks would identify these holes as a pattern and you could manipulate the bolt pattern quickly.
I like Synchronous modeling but it isn't always the best solution or the fastest.
