Color of mirrored part
For presentation purpose, I've colored model surfaces. But surfaces of mirrored part has not changed. Is there an option to copy surface colors while mirroring part?
Thank you.
RE: Color of mirrored part
Obviously not. Is it too late?
Try to edit the mirror feature and see if that option is available.
I believe the OP is using the Insert > Mirror Part method, which does not offer the "Propagate Visual Properties" option.
Yes, mirror part, not feature. So, there is no way?
