related question on best way to send model
I am now using Alibre Pro and have a customer who wants to get models that I have done photo rendered.
 The service he is using has asked that the parts be sent as Sldprt or Sldasm files. I have the capability of doing that, but as an ex Solidworks user, I seem to recall that you can dimension these files, even though I have suppressed the dimensions in Alibre. Again this is one of those jobs where we do not want somebody else making the part.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
RE: related question on best way to send model
If it's just to render, scale/stretch your model to a slightly different size in only one or two (of three) dimensions.  Blot out the innards as best as you can.
Yes I did,
I also read your answer. I just wanted additional confirmation of that.
So even if I ship this as a dumb solid, he can still dimension it with Solidworks.
B.E.
The Tick,
Thank you
I can do that, for the same reasons, I have not sent some of the files detailing the innards.
B.E.
Yes. All he has to do is create a drawing and add dimensions using the manual method. He will not be able to use the Insert > Model Items method, and will not have any required tolerances.
Cor Blimey,
Thats what I remembered and you have confirmed it.
B.E.
