Compressor design/installation requirements
I'm fairly new in the gas compression field, I have a question about what the possible minimum design/installation requirements for compressors that may be used for
1. Gas lift compressors (artificial lift)
2. Booster compressor to boost a low pressure line
3. vapor recovery unit compressors on storage tanks, etc
Requirements that may likely address things like
1. performance and efficiency
2. low emmissions from the compressor
3. safety features
4. High/low pressure shut down features
etc.
Also, does anyone know any industry codes/standards that deals with compressor design, requirements, etc
Thank you.
3. safety features
etc.
Thank you.
RE: Compressor design/installation requirements
Most of the ones I see are reciprocating
Same is true for every type of compression service you mentioned. A particular machine may be used in a VRU and then be moved to be a wellhead compressor for a single well and then become a booster somewhere else--the words just do not have any meaning.
The rest of your questions are just too vauge to even try.
David
Dresser also has some good literaturue about centrifugal units on their website.
Good luck.
