DOT requirements for UN Tanks
I am trying to locate the applicable DOT design code that applies to UN tanks.
These are tanks transportation fluids (sometimes hazerdous) and are typically enclosed in crash frames.
Is there a particular DOT regulation that spells out design requirements?  A CFR?
Thanks in advance.
Best regards.
RE: DOT requirements for UN Tanks
I first thought you were referring to the white ones that UN peacekeepers drive around in!
