connector solid by Patran/Nastran
I need some suggestion about how do I set connector between solid and solid by MSC Patran/Nastran? cause I found connector>>spot weld module but it use for surface.
If I want to set stiffness at connector point (solid+solid), can I do it?
Thank you in advance for your kindness to help me.
