Pin to Pipe Connection
How would you analyze a pin to pipe connection, where the pin is perpendicular to the plane of the pipe. The pin is connecting to a shackle, which will be pulled perpendicular to the plane of the pipe and the pin. The design is not a simple shear plate connection.
RE: Pin to Pipe Connection
Mike McCann
MMC Engineering
