advice on actuators
advice on actuators
I'm looking for an electrically powered actuator for use with something like a stamping operation.
It should have the following characteristics:
Needs to travel 10mm in 1s, precision of movement not so important, but should have a soft "landing" at the end of its travel.
Needs to apply a precise amount of force, up to 150N.
Needs to be durable for repeated movement: 10mm forward in 1s, 150N for 1s, 10mm back in 1s, 1s delay, repeat.
Anyone have any suggestions?
RE: advice on actuators
Of course, you can start looking for pneumatic, hydraulic, electromagnetic actuators, but if you want to control timing, a classical cam is easy and reliable. And motor life will be infinite since it will be running continuously - no start/stop fifteen times per minute.
Gunnar Englund
www.gke.org
I see your cam suggestion. Could put a roller on the bottom of the plunge to reduce friction. Another way might be a sliding wedge. Yet another way is an actual lever.
Motor cant operate continuously as the timing of the cycles needs to be controllable. The numbers I gave were approximate, to estimate duty cycle.
Question is : how best to precisely control the force applied.
As far as I can tell, the only way to do this properly is to build a certain amount of elasticity into the system, and to get feedback from a load cell. This gives a position to force relationship, with calibration by load cell.
In the end, the problem appears to be one of "gearing" - transforming low force large movements into high force small movements, and of "elasticity" or storing up force into some kind accumulator.
I had been looking at using a Haydon Kerk 57000 non-captive stepper motor - and using a very low lead screw to get the "gearing". A polyurethane spring gives the system elasticity.
The speed can be controlled if you use a VFD to supply the motor. given the ability of modern vector controlled VFDs, you can easily control speed very precisely and with reaction time in the 10 - 20 milliseconds range. The polyurethane spring sounds like a good idea.
Why does it have to be solid state? A VFD IS solid state, BTW. And they are extremely affordable if you compare with steppers and their controllers.
Gunnar Englund
www.gke.org
Ill read up on VFD controllers.
Many of the older installations are manually driven with appropriate reduction gearing, but I have seen electric versions, as well.
