Problem with Glue boolean-operation
I'm currently trying to define a simple 2-D geometry consiting of
different rectangular areas. When I try to glue them by aglue,all command (or modelling>operate>boolean>glue>areas) I keep getting this error:
The input areas do not meet the conditions required for the aglu operation. No new entities were created. The AOVLAP operation is a possible alternative.
and I can't figure why. I tried the overlap operation (aovlap) but I don't get the separation I want. Here's my simple code:
/PREP7
et,1,plane121
mp,perx,1,80
rectng,0,200,0,200
rectng,20,30,200,125
rectng,20,30,0,75
rectng,0,20,200,125
rectng,0,20,0,75
rectng,30,200,200,125
rectng,30,200,0,75
rectng,20,30,75,125
aglue,all
and you'll find the print-screen of my geometry attached.
Thanks for your help !!
/PREP7
et,1,plane121
mp,perx,1,80
rectng,0,200,0,200
rectng,20,30,0,75
rectng,0,20,200,125
rectng,0,20,0,75
rectng,30,200,0,75
rectng,20,30,75,125
aglue,all
RE: Problem with Glue boolean-operation
/PREP7
et,1,plane121
mp,perx,1,80
rectng,0,200,0,200
rectng,20,30,0,75
rectng,0,20,200,125
rectng,0,20,0,75
rectng,30,200,0,75
rectng,20,30,75,125
nummrg,kp,,0.01
best
priam
www.priamengineering.co.uk
unfortunetly I still get that message:"The input areas do not meet the conditions required for the aglu operation. No new entities were created. The AOVLAP operation is a possible alternative" even with nummrg,kp,,0.01.
/PREP7
et,1,plane121
mp,perx,1,80
rectng,0,200,0,200
rectng,20,30,0,75
rectng,0,20,200,125
rectng,0,20,0,75
rectng,30,200,0,75
rectng,20,30,75,125
/pnum,line,1
lplo
nummrg,kp,,0.01
thanks for your help ! Actually, I'm a beginner and I'm trying to reproduce a problem in order to train. I'm not able to differenciate the two areas acting has my load, in the post-processing, even if I apply the loads on the line. To make my self clear, I would like to get picture_1 (here attached) and I get picture_2...How can I keep the lines of the rectangulars in red and blue in my final result ?
Thanks for your help, very appreciated !
