Does countersink drill bit able to make this kind of hole?
Want to know does this drill: http ://images1 .mcmaster. com/Conten ts/gfx/lar ge/28145a4 8p1l.png?v er=4954349
Able to drill hole like the attachment? If not, what kind of drill do I need? thanks
RE: Does countersink drill bit able to make this kind of hole?
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
If you plan to do this on a conventional milling machine you will need a special cutter dia 6.2 with 45 degree angles on it, if you plan to do it on a CNC then any 45 degree chamfer cutter under dia 6.2 will do.
