ASCE 7-05 Snow and Wind Load Questions
1) On page 51 of ASCE 7-05 the figure lists the external pressure coefficients Cp for arched roofs of enclosed and partially enclosed buildings and structures, however, I could not find coefficients for arched roofs of open buildings and structures. Does ASCE 7 have any recommendations/suggestions when designing arched roof buildings that are open?
2) This next question involves both wind and snow loads. I understand that unbalanced snow loads develop when wind is applied in the transverse direction of a gabled roof structure. This unbalanced snow load develops on the leeward side and not the windward side. We have one load combination that includes DL+Unbalanced Snow Load + Transverse Wind Load (I've left the factors off) which is a legitamate combination. However let's say the wind changes direction the next day so that it is now acting in the longitudinal direction. We still have an unbalanced snow load that has accumulated on the roof but now all of a sudden the wind load has changed direction. Does the load combination of DL+Unbalanced Snow Load+Longitudinal Wind apply? Longitudinal wind will not create an unbalanced snow load on a gabled roof structure so is the load combination valid? Another argument is that the transverse wind can reverse itself and therefore you would have to consider unbalanced snow loads on each surface of the gabled roof but the code indicates that we do not have to consider this. I believe I've gotten a bit long winded on this but I just want to make sure that I am clear.
RE: ASCE 7-05 Snow and Wind Load Questions
As far as wind and unbalnced snow loads, I always use the unbalanced snow and apply the the 4 wind cases as shown in figure 6-9 (method #2).
