Fit command places components under the pathfinder? Any fix for this.
Im fairly new to SE and as such going through many of the growing pains of learning a new software. I have the opportunity to change to solidworks but im trying trudge forward and deal with this...for now.
Anyway when I use the fit screen command one of the things that irks me is that it places the left side of the component and/or dimensions under the Pathfinder. So its not actually fitting to the screen.
It would be fit to the screen if the pathfinder were not there but thats not the case. Is there any fix for this? Hopefully its just a stupid button I have yet to find somewhere. lol
RE: Fit command places components under the pathfinder? Any fix for this.
Kind regards,
Theodore
Solid Edge ST3 MP6 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
SharePoint 3.0 x64
SharePoint 3.0 x64
And now it works properly. Thank you sir for your help. Dumb little things will get ya every time.
SharePoint 3.0 x64
I have vowed to give it a fair try but thus far (while admittedly a novice at SE) its not nearly as intuitive as solidworks nor is it as customizable.
They will both do all the same things but with SE everything takes more steps to get it done.
My local rep has been good about giving me tech support.
When we first spoke and I told him about some of my issues we both agreed that it was probably because of my lack of experience. After he showed up, he confirmed the fact that "yeah SE wont do that, or that ...". And it seems like im just coming across more and more things that it doesnt do or its a pain to do (takes more steps) that right now im leaning towards SW. I dont want to have to change over but getting used to doing things less efficiently is draining my brain and taxing my time.
We will see.
SharePoint 3.0 x64
Just right off the top of my head, its shortcuts themselves.
In SW you can program single button hotkeys, even the spacebar. When most CAD guys sit down at the PC 1 hand goes on the mouse and 1 hand on the kboard. Im right handed so my left goes on the KB.
If you actually look where you place your hand most of the time the thumb is on the spacebar. After that my whole left side of my KB was all hotkeys, single keys. NO need for a bunch of finger gymnastics, I just build the keys around where my hand sets on the KB. I never have to pull my hand from the mouse and my screen has very few buttons on it. The letter Q could do 3 or 4 different things when combined with combined with alt,Ctrl or just by itself, which all the most common commands get single keys.
I also program usually 5 button on my mouse. Setup like this its easy to get to the point where you think faster than the PC can react. And it does save time.
Smart Dimension in Edge to me just an oxymoron. Try measuring something on an angle. In edge you have to go to your box then change the settings from horiz/vert to then place your dim (dont remember if you have to change it back).I hate window washing with the mouse. Plus some dimensions you have to use dist-between or any of the other ones they have.
In SW you click the position and it instinctivly knows what your trying to do, you just place the dim wherever you want. No window washing or switching boxes or stuff like that.
There are more things but this is a long enough post. LOL
SharePoint 3.0 x64
As far as the ctrl and alt on the smart dim, its doesnt always pull the proper dimension or in the proper direction when its used. I have found errors using that method. The only sure I know if is to change the settings in the box.
By all means have a good night and any tips or pointers you have, im all ears.
Thanks for your time.
If you pick an angled line it will first give the length.
Hold the SHIFT key and drag left or right it will give the vertical height, drag up or down and it will give the horizontal length.
Press the 'A' key and you will get the angle, either from vertical or horizontal depending on where you drag the mouse.
On a circle it will show diameter, but try posiitioning your mouse at the top/bottom/left and right quadrant points.
If you use Smart Dimension on an arc it will first dimension the radius. Press the 'A' button for length or 'A' again for arc angle.
Dimensioning between points - hover the mouse over a line and press 'M' to get mid point, or 'C' for the centre of a circle or arc.
If you just click on the circle it will automatically pick the centre, just avoid the quadrant points.
When dimensioning between 2 circle or arcs pressing the 'T' button will toggle between keypint selection and tangential selection.
Simples.
Please don't compare CAD systems, they all work differently - if you want something that works like Solid Works then use Solid Works. I'm sure you would be just as frustrated if you went from SE to SW.
By the way, many people, including myself, have their left hand on a Spaceball, so having keyboard shortcuts is not really much use.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
http://www.dezignstuff.com/blog/?p=4052
SharePoint 3.0 x64
CTRL + F Front view
CTRL + L Left view
CTRL + T Top view
CTRL + B Bottom view
CTRL + K Back view
CTRL + I take a guess!!!!!!!!!
CTRL + J Dimetric
CTRL + M Trimetric
CTRL + Q Show/Hide previous level (when in Edit-in-place hides other assembly parts)
CTRL + RMB Zoom
CTRL + Shift Rotate
CTRL + SHIFT + RMB Pan
For a complete list of default keyboard shortcuts see the help, and search for 'Shortcuts'.
TBH there are far too many to remember - that's why I rarely use them
If you go to the ribbon customisation window you can set up your own combinations.
bc.
Quadro FX4600.
