Creating Planes & Axis Systems In The Product Environment
Using Catia V5R19;
Is it possible to create planes & axis systems in the product environment without having to create dummy parts?
Any response will be greatly appreciated!
RE: Creating Planes & Axis Systems In The Product Environment
You need to use skeleton based design in Catia.
Product
  Reference part
  part
  part
  part
  sub product
    part
regards,
Derek
Can you indicate the commands to go through to achieve this?
Derek, does your approach require creating dummy parts?
Sometimes I use a dummy part, mainly for positioning or if I need planes from absolute space.  Most of the time I can get away without. I use assembly constraints and build all items around their respective zero.
I don't want to use dummy parts because I'm also using SmarTeam, which is not a forgiving file managing software. Most of the time, the first part I start with I will design around so I would like to position it the way I like. If the part is designed with a different orientation, without the presence of planes and/or axis, this is not possible.
