Dry-Type Transformer
Hello all,
I have a question about the main difference between the VPI dry type transformer,cast-coil ,cast-resin and resin encapsulated in the production process?
Thx in advance
Thx in advance
RE: Dry-Type Transformer
In our time VPI dry type transformer, cast-coil ,cast-resin and resin encapsulated are basically the same
thing as the procedure is based always on Vacuum Pressure Impregnation using more or less the same epoxy resin -Araldite or else and the result is cast-resin coil.
Some fiberglass reinforcement is provided also.
The resin encapsulated is a transformer encapsulated in a metallic envelope and could be simple or double insulated according to application request.
On the web you may find infinite number of articles explaining the technology. For instance:
http://www.kilred.com/vpi/faq/faq.html
ht
ht
http://www.jstusa.net/products.aspx
And maybe that is because we like bigger transformers.
