Tracking spare parts of subassemblies of end products
Hello experts :)
This problem is way out of my league so I will try to explain it with an example
Spare brains required!
Example:
My customer has bought 10 cars, and now want to buy their pistons for future maintenance. He had previously received our documentation about spare parts. We do not want to tie the spare part lists to each lot/serial number to avoid publishing the lists in real-time. He then has to be able to find, via a kind of revision number on the cars nameplate, the right part list. From our side, we need to increase the revision number to track changes on spare parts.
My problem is that pistons are not at the first level of the BOM but are inside the motor assembly which is stocked before being used.
I do not want the customer to need to look on a label on the motor and do not want to write on the car's nameplate the revision of the motor, I would like a global revision number.
Is it possible?
Example:
Is it possible?
RE: Tracking spare parts of subassemblies of end products
Nobody stocks or sells individual parts anymore; they only stock 'kits', or 'units' or 'FRU's, which seem to be grouped so that you always walk away from the parts counter poorer by at least $100, even if the part you actually need should only cost $1.
E.g., you can't buy a door latch, or a door latch operating rod, or a Tinnerman clip that retains the door latch operating rod to the door latch. All you can buy is a kit that contains every damn part for a door assembly but the door itself.
Similarly, you may not be able to buy just a piston, but an assembly comprising piston, pin, rings, connecting rod and cap, and bearings.
I think you can see the advantage >to the manufacturer< of stocking and selling only kits. Now, you have to find a way to sell your customers on accepting that practice as standard.
Mike Halloran
Pembroke Pines, FL, USA
You could just go very conservative in your doc control, chasing all changes up through the drawing pack so that the top level designation changes every time a different spare would be required.
Alternatively (or possibly additionally),it may be that you actually prepare a 'FRU' or spares list or similar for each 'model'. You still need good config control to make sure that changes are tracked and the 'model' designation changed accordingly and the spare list updated.
Or, for lower volume stuff, it may be that you assign a serial number to each unit and take a 'snapshot' of the rev of all relevant documentation when it was built and store this information in a data base of some kind. (In lieu of each unit your could do each batch/block).
Then there are the various combination's/extrapolations of the above.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
