Couple questions on BOMs
1. I can add a new column to a BOM on a drawing, but I can't figure out how to link that column to a specific component/part property, such as vendor. How do you do that?
2. Does Solidworks have any way of exporting BOMs as a spreadsheet file?
3. If so, is there a way to generate and export a custom BOM that isn't displayed in any drawing files?
RE: Couple questions on BOMs
1. When you add the new column there is a dropdown menu that allows you to select the custom property.
2. Right click in the BOM and select Save As.
3. Dunno, but I doubt it unless one of the API gurus can make a macro.
Dan
www.eltronresearch.com
Dan's Blog
BOM in Drawings;
http://
BOM in Assy;
http:
Old AssemblyBOM.swp macro attached
