FFT implementation for harmonics
Hi I am trying to run the fft command on my matlab waveform that I generated.
I created a superimposed waveform of to generate harmonics. The fundamental frequency is 60 Hz and the high frequency is 900 Hz. I want to be able to show each of the harmonics in the FFT spectrum
The sampling frequency used here is 2000 Hz since high frequency is 15*60 Hz = 900 Hz. Ideally the amplitude of the spectrum should decrease as the frequency increases after doing fft.
This is the FFT code that i created:
I am not getting the correct amplitude spectrum. I am pretty sure I am doing something wrong with the fft code. Plz help!
CODE
a = 1; % alitude
fHz = 60;%*i; % Hz
fRads = 2*pi*fHz; % freq rad/sec
t = 0:0.0005:1 ; % sampling time
y = (a * sin(fRads * t))...
+ (0.65*a * sin(3*fRads * t)) ...
+ (0.55*a * sin(5*fRads * t))...
+ (0.45*a * sin(7*fRads * t))...
+ (0.35*a * sin(9*fRads * t))...
+ (0.25*a * sin(11*fRads * t))...
+ (0.15*a * sin(13*fRads * t))...
+ (0.05*a * sin(15*fRads * t));
fHz = 60;%*i; % Hz
CODE
Y = abs(fft(y,2001));
%Y = fft(y,NFFT)/L;
%f = 128/2*linspace(0,1,NFFT/2+1);
f = 0:2000;
plot(f,y,'-x'),title('N =2000'),axis([0 900 0 20]);
% Plot single-sided amplitude spectrum.
%plot(f,2*abs(Y(1:NFFT/2+1))) ;
title('Amplitude Spectrum of y(t)');
xlabel('Frequency (Hz)');
ylabel('|Y(f)|');
%Y = fft(y,NFFT)/L;
f = 0:2000;
ylabel('|Y(f)|');
RE: FFT implementation for harmonics
> Your sampling rate is too low to guarantee spectral purity. It's barely a factor of 2 higher than the highest frequency. You should sample at something like 50x the max frequency to ensure no pathological sampling artifacts.
> Every FFT implementation is slight different. You need to verify and account for the scaling factor.
TTFN
Chinese prisoner wins Nobel Peace Prize
- Steve
LinkedIn
Dr Michael F Platten
Beware that the DC and Nyquist frequency bins need only be divided by L, not L/2. (If they are important to you).
- Steve
LinkedIn
CODE
(2B)+(2B)' ?
