Excluding the surface name in Inroads Cross Section Annotation
I have successfully annotated a cross section set generated from a surface using INROADS XM. Everything has turned out nicely, except the annotation for my Features includes the surface name.
For example, the feature name is ES_L and the annotation will display as HL4-ES_L where HL4 is the surface name.
Does anyone know how to exclude the surface name in my Feature names?
Any help would be appreciated.
Thank you,
JCatch
RE: Excluding the surface name in Inroads Cross Section Annotation
Just for clarification, It may not be the surface name but the alignment name...
Either way, I'd like to remove it from my features annotation.
