Serious pump problems
Hello all. I am new here and was wondering if you could help me out. We have a "brand new " installation of 3 VFD operated, 600hp End Suction Horizontal 12 x 14 Centrifugal pumps rated at 5780 gpm @ 233 ft. Since day one they have vibrated excessively(.80 to 2.5 in/sec RMS). I thought the manufacturer was Holy Sh**! or Shut it down! since that was usually called out when it ran. The manufacturer is saying that it is vortexing that is causing the vibratione even though there was 18+ ft of head and minimal flow at the time. We had a detailed (expensive) vibration analysis done by a well respected company. They indicated that the shaft was wobbling due to inadequate effective stiffness in the bearings and a poor structural strength of the base. We can't use the pumps (going on 2 years now)and the manufacturer is obstinate about the cause. My question is am I missing something or have the laws of physics been suspended regarding the vortex issue.
Has ayone run into a situation like this and if so what was the resolution.
Thanks in advance for you time.
RE: Serious pump problems
Dik
You have not said anything about the pump arrangement. The pump arrangement is critical. It is possible that you may have flow currents in the wet well that are causing a problem.
Get a copy of Pumping Station Design and review the design recommendations for pump stations
Pumping Station Design, 3rd is an essential reference for all professionals. From the expert city engineer to the new design officer, this book assists those who need to apply the fundamentals of various disciplines and subjects in order to produce a well-integrated pumping station which is reliable, easy to operate and maintain, and free from design mistakes. The depth of experience and expertise of the authors, contributors, and peers reviewing the content as well as the breadth of information in this book is unparalleled making this the only book of its kind. An award-winning reference work that has become THE standard in the field. Dispenses expert information on how to produce a well-integrated pumping station that will be reliable, easy to operate and maintain, and free from design mistakes. 60% of the material has been updated to reflect current standards and changes in practice since the book was last published in 1998. New material added to this edition includes: the latest design information, the use of computers for pump selection, extensive references to Hydraulic Institute Standards and much more.
http:
And by the way, love your handle.
Schematic would be a help. Also answering above question about type of pump would help.
