ASME II Part D
ASME II Part D
Hello!
The criteria for establishing allowable stress table 1-100 of the ASME II Part.D also apply to seamless tubes?
Greetings.
Greetings.
RE: ASME II Part D
Mike
RE: ASME II Part D
Answer to your question is "yes".
Seamless tubes fall under first row of Table 1-100 while welded tubes fall under second row of Table 1-100.
For welded pipes or tubes, allowable stresses are lowered by 15% as those seamless.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
RE: ASME II Part D
RE: ASME II Part D
