Bolt Circle Hole Pattern
I have created a bolt circle hole pattern by creating a "diameter" style hole and patterning it by the angle dimension. I would like to show the centerline that represents the bolt circle on my drawing but I can's seem to show it with the show\erase command. Any tips are appreciated.
Ken Johnson
ITT Industries, Engineered Valves
RE: Bolt Circle Hole Pattern
Change the option RADIAL_PATTERN_AXIS_CIRCLE to YES (NO is default) value in the DTL file or in ADVANCED->DRAW SETUP->MODIFY VAL.
-Hora
steve
http://www.3dlogix.com
