system supports
system supports
system supports
I am attaching a model with anchored supports already attached and some hanger rods also. My question is, are the hanger rods properly designed in Caesar II? If so, what would be your advice on how to support this system? Continue using hanger rods, or switch to something esle? As you will see, the system is at the very start not flexible.
