Measure eye-diagram using a scope
I would like to measure the eye-diagram of the DDR's clock.  What do the oscilloscope probe connections look like in order to display the eye-diagram?
Also, the DDR clock is 133MHz, what's the required oscilloscope bandwidth?  If I use a 2pF FET probe to probe the clock, will it be OK?
Thank you in advance!
James
