Magnetic center and alignment
Friends i have a little confusion over motors having magnetic center. When a motor is at rest, the shaft is on the magnetic center. We carry out alignment at this rest condition. Now when the motor starts it runs on magnetic center.
How does the coupling accommodates this axial movement?
or is there any precautions to be taken during shaft alignment?
RE: Magnetic center and alignment
(2B)+(2B)' ?
If your question is not answered, can you please re-state the question?
(2B)+(2B)' ?
Typically, there is a means of showing the motor's magnetic center as determined by a factory or shop test run. The prudent man will do a test run with the motor in its final location to verify the REAL magnetic center.
The magnetic center is the driving parameter for alignment and coupling. Failure to consider magnetic center results in axial loads in places they should not be.
In explaining these ideas to some mechanical people on a recent project, I pointed out that all that magnetism that wants to spin that motor to produce 22,000 horsepower ALSO wants that motor at magnetic enter, and did they REALLY want their coupling to fight 22,000 horsepower pushing endways on that coupling and the compressor up the shaft from it.
old field guy
does your motor have a thrust bearing, if so, whoever built the motor and set the thrust set how close to electrical center it will be.
If your driven also has a thrust, then the coupling must allow for some float and that float is determined by the thermal expansions of the the two rotors and the thrust positions.
if your driven has no thrust, it will require the coupling to be solid to set its running axial position. this is the case with most centrifical oil pumps
if the motor has no thrust, then the driven will. if the thermal expainsion of the driven end of the coupling is great, then flaot in the coupling could be used or the coupling made solid but with a cold offset so the motor starts off magnetic, but is near at running temp.
Being dead on magnetic center can cause axail vibration and a lot of applications preferrr to have the motor "push" the driven
does the driven have a thrust?
1. Both driver and driven have thrust
2. only driver has thrust
3. only driven has thrust
4. no thrust at all.
what would be the scenario in the above four cases?
1) need float
2) no float needed, but coupling must set driven axial position
3) no float needed
4) the device will destroy itself of coast down or starup
Also how much float ?? how do we give float?
the desired coupling float is determined by the design.
the mechanism for float is in the design of the coupling. all flexable couplings will have float, but the selection of components will establish the amount desired, ie grid spring, gear hub lenght. a true solid coupling will have no float.
is this for class room discussion or home work since the questions are so non specific
E.g. if mag center is lying X mm from mech center (outside motor). Then X mm is subtracted from DBSE and accordingly DBSE is set before start up of an equipment.
I think you have hit on the real answer in your last question.
rmw
