Conveyance pipe thrust collar
I have an 84 inch diam. conveyance pipe going into a 4 foot wide tank slurry wall that I need to design a restraint system for. The pipe has a calculated 145 kip thrust that needs to be balanced by the slurry wall.  I am looking for some design examples of how to do this. Any help would be great.
RE: Conveyance pipe thrust collar
Looks like you could build that portion of the tank wall as a retaining wall, or simply locate a pipe anchor block near to the tank wall to hold that thrust.  Rather than a sleeve, can you use an integral pipe anchor flange-type design wherever you anchor it, basically a double necked flange with no joint in between flanges (where the gasket would normally go).
http://www.buffaloflange.com/anchorflange.html
We will design everything from now on using only S.I. units ... except for the pipe diameter.
