10 cpm phase AND unsteady, non rotational frequency vibration
Looks like we need to capture at least 2, and preferably at least 8 channels of simultaneous low frequency (600 cpm down to 10 cpm or so) "vibration" data.
Also, must process it for relative phase and amplitude (etc?) to determine if a mounting flange is yawing or pitching > 1/8 degree.
Any suggestions?
thanks,
Dan T
RE: 10 cpm phase AND unsteady, non rotational frequency vibration
Hi Tmoose,
Are you dealing with a speed that varies from 600 down to 10 RPM and you need to know the phase relationships over the entire range?  Or, is it a fixed speed machine and that is the frequency range of interest?  If the latter is true do you have a single dominant frequency in that range?  Are you really looking for phase resolution better than 1/8 of a degree between channels?  I guess I really don't understand the scope of the project.
http://www.machinerywatch.com
