Uplift Capacity of Belled Caissons (Drilled shafts with a bell)
How do you take into account the bearing capacity against the bell when calculating the uplift capacity of a belled caisson? Can this component of resistance be combined with the frictional resistance along the shaft?
RE: Uplift Capacity of Belled Caissons (Drilled shafts with a bell)
Only if the rebar cage extends into the bell.
Well...you do get some resistance from the shear strength of the concrete at the bell/shaft interface also.
