Help - How to access Siemens' IBS Tool
HELP – IBS Tool Access
We wonder if it is of public knowledge, but whether or not, we believe it is important to publish this information that is going to be of great help to power systems engineers or anyone involved in the wide world of electrical protections.
Seems weird and illogical but this information is not clearly explained within the pages of Siprotec numerical protection relays' manuals or commissioning documents. Because of this, we think it is our duty to share the information acquired through lab testing experiences.
The information which we are going to share is the way to access to IBS tool. In the rush to find relevant data to access this tool we found this useful link:
http://siemens.siprotec.de/download_neu/applications/tipps+tricks/Schutz/IBS_WebMon_XP_en.pdf
Is important to stress out that this link was obtained after a deep search on internet, though we think it should be published on the manuals or at least be easy to find with just a few keywords.
After strictly following the steps described by the document, we couldn't get any positive result. So we got to do some trial and error tests.
We ought to correct the following directions:
1.    Modem Installation
a.    When installing the modem, we didn't do it with the speed recommended by the pdf link (couldn't' obtain successful results when installing a 28000 bps modem), but the speed recommended by the "DIGSI 4" disc, which is 33600.
b.    Following the installation, when the moment comes to select the COM port, is not important which one you choose. But, the port chosen will always be the port in which the data transfer between the Siprotec relay and the computer will be carried out.
c.    When configuring the port speed, the one which should be selected is the operation interface's and not the service interface's speed. Example:  for the Siprotec relays 7UT6** the operation's speed is 57600 and for the Siprotec relay 7SD is 115200.
2.    Configure Network Connection
a.    When writing the username and password, the full access password "000002" for the relay should be entered.
b.    In the modem configuration window, the speed that we've already set in the modem installation step must be entered, in other words the operation interface's speed of the Siprotec relay.
c.    If everything has been done right, we can establish a connection with the protection relay. Though, in order to access the web monitor, we've got to obtain its IP address, which in our case was: 192.168.1.1. This address should be written in our favourite web browser, but it should have the latest Java version installed to work properly.
d.    Enter the IP on the web browser, and enjoy the benefits that this useful tool can provide, which in our concept should be integrated in the DIGSI software.
Authors:
EGSV (EC)
IRVC (EC)
Ayuda - Acceso a Herramienta IBS (Siemens)
No sabemos si es de conocimiento general, pero creemos que no esta de mas si anadimos a este foro, cierta información que les va a ser util a otros Ing. en Potencia u otras personas involucradas en el amplio mundo de las protecciones eléctricas.
Parece raro pero la siguiente información no esta claramente explicada dentro de los manuales de puesta en servicio de los relés de protección numéricos Siemens-Siprotec, es así que nos vemos en la obligación de compartir esta información obtenida a través de experiencias de pruebas en laboratorio.
La información a divulgar es la forma de acceso a la herramienta IBS (IBS Tool).  En el afán de búsqueda para poder acceder a esta herramienta pudimos encontrar el siguiente link:
Cabe resaltar que este link lo obtuvimos luego de realizar una búsqueda profunda, la cual debería ser de conocimiento público y ser sujeta a poder ser encontrada con unos cuantos keywords o al menos ser publicada en los mismos manuales.
Luego de seguir los pasos que constan en dicho documento,  no obtuvimos resultados positivos. Por lo tanto tuvimos que realizar ensayos de prueba y error.
Debemos corregir los siguientes puntos:
a.    Al instalar el modem, no lo instalamos con la velocidad que recomienda el archivo PDF (ya que con la velocidad de 28800 bps no obtuvimos resultados satisfactorios), sino con el que recomienda el instalador de aplicaciones que se encuentra en el disco "DIGSI 4", que es de 33600 bps.
b.    Al seguir con la instalación, al momento de seleccionar el número del  puerto de comunicaciones, debemos recalcar que no es de importancia el  número del mismo. Sin embargo, el puerto escogido será siempre el puerto físico en el cual se realizara la transferencia de datos entre el relé y la computadora.
c.    Al momento de configurar la velocidad del puerto, se deberá ingresarse la velocidad del interfaz de operación y no la velocidad de servicio. Ejemplo: en el relé 7UT6** la velocidad de operación es de 57600, en el relé 7SD es 115200.
a.    Al momento de setear el username y password hay que escribir en el campo password, las clave de acceso completo del relé que es 000002.
b.    Al momento de estar en la ventana de "modem configuration", hay que poner la velocidad que ya pusimos en los pasos de modem installation, es decir la misma velocidad de operación del relé.
c.    Si todo lo hemos hecho de manera adecuada, en estos momentos podemos establecer la conexión con el relé de protección. Sin embargo para poder acceder al navegador del relé, debemos obtener primero tener la dirección IP del mismo; que en nuestro caso fue:  192.168.1.1. Esta dirección IP debemos escribirla en nuestro navegador de internet favorito, sin embargo el navegador debe tener la ultima versión Java disponible en internet e instalada en el ordenador.
d.    Ingresar el IP en el navegador y listo, podemos acceder a las bondades de esta herramienta, que para nuestro concepto se debería poder acceder directamente a él desde el DIGSI.
Autores:
EGSV (EC)
IRVC (EC)
