SimMechanics: translational body spring damper system with friction
To test the Joint Stiction Actuator block in SimMechanics, I made a small model containing 2 bodies, a prismatic joint and a spring/damper. The actuation is a body actuator which yields a force step input after 2 seconds.
The goal is to put friction into the shock absorbers in a full vehicle multibody model.
To get this small test model running it took me quite some time. At this moment it sometimes runs without problems, sometimes it runs very slow, other times it freezes (simulation is running but no progress can be seen, also the simulation time stops), and sometimes it gives an error after some seconds of running. To check, just change the constants at top right corner, the spring constant, the step value (force actuation) or the damping coefficients.
Is there anyone who has experience with this Joint Stiction Actuator, or with modeling friction? Also if there are some faults in the model, please let me know.
A printscreen of the model can be seen here:
http://im ageshack.u s/photo/my -images/58 5/damperte stmodelexp laine.jpg/
The model can be found here:
http ://www.2sh ared.com/f ile/FKmQ2i wn/test_da mper_frict ion_3.html
Or here:
http://www.megaupload.com/?d=9UKH2LHZ
http://im
http
Or here:
RE: SimMechanics: translational body spring damper system with friction
For a spring mass system the friction can be input as a force proportional to the velocity of a joint.
For eg. the DE of
m*xdd+c*xd+k*x=F+applied-mu*xd
So you can sense the velocity of a joint and multiply it by mu, and then feed it as a force onto the rigid body.
Your model likely fails to run when it is near or at a singularity. This is very common. Just keep your stiffness and other parameters in the stable region.
Seems that the block you are using is made for friction modeling. It should work fine.
h
Fe
I also used that help page to get some information on how to use that block, but there are still some thing not functioning totally correct.
Based on answers I got on another forum, I made the following changes to the model:
* This is a numerically stiff system, so use a stiff solver (ode15s or ode23t)
* Leave the max step size to auto, and maybe change the AbsTol to 1e-4
* I think you need to subtract the external actuation signal from the computed force to work out the static friction force
* When computing the normal force, you need to include the z axis ( sqrt(u(1)*u(1) + u(2)*u(2) + u(3)*u(3)) )
However I still get an error, even when using the solvers above. Anyone some more tips/corrections?
Ok, I made some changes and now it does seem to work. But I still have a few question about the reasons:
- Shouldn't I also include the external actuation force (which actuates the body) to calculate the static friction. This one will also affect the Computed Force in the joint, no?
- Why is it necessary to include the force in z-direction to calculate the total normal force? Only the forces in x- and y-direction are perpendicular to the movement direction. And isn't it mostly the perpendicular force multiplied with the friction coefficient to determine the friction force?
Maybe someone can help with these questions?
