bearing hole size on 7075
I need to drill a hole for install a bearing. The part make by 7075-T6. The bearing size is 6mm. I want to know what should be the hole size on the part for bearing? I need the bearing to be able to push in by hand and do not drop off when flip over. thanks
RE: bearing hole size on 7075
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Is this a plain bearing?
If you're really just asking about calculating press fits then maybe do a search on that topic, it comes up often. For instance thread404-151892: need press fit formula.
More at http:/
If you drill a 6mm hole then it should fit in assuming your tolerances are OK.
How about putting some heavy grease on the bearing that will make it "stick" in the hole??
Mike Halloran
Pembroke Pines, FL, USA
You are going to take all the fun out of the job. Using that stuff you can push the bearing in with your finger, and know that after 15 mins you will need a crowbar to get it out.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
